Cheap tractor for hauling a trailer, with one remote
   / Cheap tractor for hauling a trailer, with one remote #1
ishiboo
Platinum Member
Oshkosh, WI
Kioti NX6010HSTC, Cat 279c
I'd like a cheap tractor for hauling a small dump trailer (5000lbs?) on level dirt. The Ford _n series would be fine, except I need a single remote or the ability to add a remote easily for running the dump cylinder while retaining 3-point lift capability. Electric dump is not an option.
What should I be on the lookout for? Don't care about the transmission type, gear is fine.
   / Cheap tractor for hauling a trailer, with one remote #2
I believe some of the older farmalls had a factory single acting hydraulic remote for applications like this. They are quite cheap. I have a super M that I paid 1,000 for and I run it 4-5 times per day every day and it does just fine.
   / Cheap tractor for hauling a trailer, with one remote #3
Any old tractor with a single remote, most Allis Chalmers D series tractor came this way an if not restored usually can be had at a decent price.
2023 JOHN DEERE 3033R LOT NUMBER 90 (A53084)
2023 JOHN DEERE...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2008 AAR MOBILITY SYSTEM REFRIGERATED BOX (A52576)
2008 AAR MOBILITY...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
