Check My Specs and math
   / Check My Specs and math #1
fluffhead31
Colchester, Vt
NH TC35A w/ 16LA FEL
Tractor (bare) = 2628lbs
Loaded Tires: 600lbs x2 = 1200lbs
16LA FEL = 1100lbs
Total Tractor Weight= 4928 lbs
Trailer Weight=1700
Total Towing Weight:6628
The vehicle i am using (2010 gmc canyon v8) has 6000lb max towing capacity. Do you think i can handle it?
   / Check My Specs and math #2
To close to the edge for me. Other factors like tralier length and tongue weight need to be considered as well.
   / Check My Specs and math #4
Might be okay for an occasional short trip. If you don't need the loader you can easily lighten the load.
   / Check My Specs and math #5
What tractor do you have???
A 2600lb tractor is not very big and 600lbs ballast in each tire requires some pretty big tires. I may be wrong but it doesn't add up to me. My L3400 weighs 2600lbs as well and ~250lbs of liquid is about all that will fit in the R1's that come on it. I know R4's can hold a little more, but 600lbs is a LOT more.
   / Check My Specs and math #6
16LA FEL = 1100lbs
Trailer Weight=1700
What in the world is a Canyon? I do not stay up on GM stuff but only 6,000# tow rating on a V8??? Seems awful low. I guess if its a little truck with a big engine.
As for the loaded tires I think you are high. My tractor has 10x24 ags and loading both only added 400# or so.
Chris
   / Check My Specs and math #7
I too think that your tire weight sounds high. As far as towing, it really would not be safe at highway speeds. As mentioned, if only going short distances that do not exceed say 45mph, I would do it. Instead of guessing on the weight of the total combo, go and get it weighed and know for sure.
Just my opinion. ;)
   / Check My Specs and math #8
<snip>
Although I would be worried about towing capacity, I would be more worried about stopping capacity.
Steve
   / Check My Specs and math #9
This might help.
Liquid Tire Ballast
The following table represents the weight achieved by filling the tire 75% full (valve level) with water.
Use of chemical agents to prevent freezing will affect the weight.
Farm Tractor Tires (Turf tires can be found below this chart)
TIRE SIZE, GALLONS OF WATER, ADDED WEIGHT (lbs.) PER TIRE
tire size gls weight
4.00-12 2 17
4.00-15 2.5 21
4.00-19 3 25
5.00-15 3.5 29
5.50-16 5 42
6.00-12 4.5 37
6.00-14 5 41
6.00-16 6 50
6.50-16 7 58
7.50-10 6 50
7.5L-15 8 66
7.50-16 9 75
7.50-18 10 83
7.50-20 11 92
9.00-10 9 75
9.5L-15 11 92
9.50-20 18 150
9.50-24 20 167
10.00-16 17 142
11.00-12 18 150
11L-15 13 108
11.00-16 23 192
11L-16 15 123
14L-16.1 27 225
16.5L-16.1 42 346
7.2-24 9 75
7.50-16 9 75
8.3-24 13 108
9.5-16 12 100
9.5-24 17 142
9.5-36 25 209
9.5-42 29 242
10-16.5 12 97
11.2-24 24 200
11.2-28 27 225
11.2-34 33 275
11.2-36 35 292
11.2-38 36 300
12.4-16 21 175
12.4-24 30 250
12.4-28 35 292
12.4-36 44 367
12.4-38 46 384
12.4-42 51 425
13.6-24 38 317
13.6-26 40 334
13.6-28 43 359
13.6-38 57 475
14.9-24 47 392
14.9-26 48 400
14.9-28 53 442
14.9-30 57 475
14.9-36 64 534
14.9-38 67 559
15.5-38 66 550
16.9-24 61 509
16.9-26 65 542
16.9-28 69 575
16.9-30 73 609
16.9-34 82 684
16.9-38 90 751
17.5L-24 55 459
18.4-16.1 49 409
18.4-24 75 626
18.4-26 79 659
18.4-28 84 701
18.4-30 89 742
18.4-34 100 834
18.4-38 110 917
19.5L-24 73 609
20.8-34 128 1068
20.8-38 140 1168
Turf Tires
23x8.50-12 6 50
23x10.50-12 7 58
26x12.00-12 10 83
25x8.50-14 7 58
25x7.50-15 6 50
25x10.50-15 7 58
25x12.50-15 8 67
27x8.50-15 7 58
27x9.50-15 9 75
27x10.50-15 10 83
29x12.50-15 14 116
31x12.50-15 18 149
31x13.50-15 19 158
31x15.50-15 20 166
33x12.50-15 22 183
44x18.00-20 56 476
   / Check My Specs and math #10
It would be nice to know what tractor we are dealing with here.
I am not up with the NH's but I think the smallest tractor they put the 16la on was the TC35. Wich would have the 17.5L-24 tires which hold 55gal.
If calcium was used @ ~11 lbs per gal, that would indeed be 600lbs a tire. BUT a TC35 doesnt weigh 2600, it is more like 3300lbs.
Just too many if's with out knowing the tractor and what was used for ballast.
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2012 Honda Civic Coupe (A50324)
2012 Honda Civic...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
