Oct 24, 2006 / Check this out - animated engine assembly #1 dmg Member Joined Mar 18, 2006 Messages 40 Location Danville Indiana Tractor JD 2305 Borrowed from another forum that I frequent. Very Cool!!YouTube - 3D Deutz engine animation
Oct 25, 2006 / Check this out - animated engine assembly #2 D Doc_Bob Elite Member Joined Mar 17, 2006 Messages 3,306 Location Wisconsin Tractor 2003 NH TN70A Spark plugs?????? Sorry, if it requires a spark plug, it is not a "real" engine. Bob
Oct 25, 2006 / Check this out - animated engine assembly #3 SkyPup Elite Member Joined Dec 3, 2003 Messages 3,079 Location North Central, Florida Tractor Kubota L-39 GST TLB, Kubota L3130GST, Massey 1030 HST, Kubota ZD-21 ProDecK, Two Euro VW TDIs Deutz is one of the oldest diesel engine manufacturers on the planet.
Oct 25, 2006 / Check this out - animated engine assembly #4 PineRidge Super Member Joined Oct 8, 2003 Messages 7,595 Location Northeast, Ohio Tractor LS-MT242HC I especially liked the clip where the guys were doing 165 MPH gum-ball racing to Miami.
Oct 26, 2006 / Check this out - animated engine assembly #5 C Chuck52 Veteran Member Joined Aug 13, 2001 Messages 2,184 Location Mid-Missouri Tractor Kubota L210 Is that how an inline four would normally be sequenced? With two sets of two cylinders firing together? Chuck
Oct 26, 2006 / Check this out - animated engine assembly #6 PineRidge Super Member Joined Oct 8, 2003 Messages 7,595 Location Northeast, Ohio Tractor LS-MT242HC Chuck if you look again I don't believe that any two cylinders fire at once. That way the engine runs smoother. It is true that 2 cylinders do reach TDC at the same time but one is exhausting wile the other is firing.
Oct 29, 2006 / Check this out - animated engine assembly #7 RonMar Elite Member Joined May 25, 2005 Messages 3,002 Location Port Angeles WA Tractor Jinma 284 delivered 06/28/05 A standard inline 4 cylinder 4 cycle has 1 and 4 coming to TDC together and 2 and 3 moveing together. The fireing order however would be 1,3,4,2.
