checking hydraulic fluid
   / checking hydraulic fluid #1
VietNamVet
Maxville, Fl
Mahindra 6010
When checking the hydraulic fluid on a Mahindra 6010 with FE loader and backhoe do you check it with the engine running or engine off? With loader up or down, backhoe extended or up?
   / checking hydraulic fluid #2
My manual says to check with the backhoe up and locked in transport position and FEL in down position. I don't think it will make any difference if engine is running or not, but it isn't necessary for the engine to be running (not like an automatic transmission that you check with engine running.)
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53472)
2016 Ford F550 4x4...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
ECHO PB-2520 GAS HAND HELD BLOWER (A51248)
ECHO PB-2520 GAS...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
