ChiCom Slip Clutches At Tractor Supply....... Any Good?
   / ChiCom Slip Clutches At Tractor Supply....... Any Good? #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
I plan on adding a slip clutch to my old rotary cutter which currently uses a shear bolt for protection. The local TSC has the one I need in stock. I see the are stamped 'made in China' on them, which is not inherantly bad. Just wondering if anyone had had any luck with them, good or bad. I figured I'd pick one up locally if possible.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
