Backhoe China dozer with backhoe hookup
   / China dozer with backhoe hookup #1
chuckinNC
Has anyone added a backhoe to one of these yet, mine has
a 3pt on the back, Im thinking of a medium wieght hoe but
want to plum into the dozer hydraulics. I dont see a power
beyond port on the valve, these dozers came with a hoe in
past years so im thinking there should be a easy way to couple into the system.
   / China dozer with backhoe hookup #2
I belive the gullian dozers used to use the same JW03 hoe that came on the JINMAS and also had the same PTO pump for the hoe that the JINMAS used (same shaft inside the dozer ect.)
anyhow I'm not 100% on these so maybe CHIUP or GRHAM will chime in.
Makrm
   / China dozer with backhoe hookup #3
The Hoe was originally built by Guilin and OEM'd by Yancheng.
I believe Yancheng bought the rights and now builds them all
with the nice fit & finish features like the rounded tanks of the
original Guilins. The mounting kit is different for the Dozer but
the pump could be the same since the back end is very similar
to a 354.
Graham
   / China dozer with backhoe hookup #4
Been researching 30hp dozers, getting DH326RT with LW-6 backhoe and Gu306 loader, Tractor Connection is very helpful, hydraulic shift requires additional pto hydraulic pump, seen backhoes 3 point and solid mounted on same units at 2 dealers, many name plates and colors, yet same unit. was informed backhoes above the LW-6, weight/work load could be a issue. /forums/images/graemlins/laugh.gif
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
