Chipper Chipper Blades
   / Chipper Blades #1
dking
Bronze Member
New Brunswick, Canada
Kioti DK45SE / Massey Furguson 165
How often would chipper blades need to be sharpened, roughly in hours? For that matter, how often would you have to replace the blades? These questions are assuming normal use and not feeding any wire or rebar thru the chipper...
   / Chipper Blades #2
I am curious on how you know about wire and rebar in a chipper? :D Or should I not ask? :D
   / Chipper Blades
haha - no I didn't feed any wire or rebar thru a chipper :D - just wondering how much 'normal' use before blades need to be sharpened.
   / Chipper Blades #4
Totally depends on what you are chipping. soft wood, hard wood, how much soil on it. Can be as often as every day or may be several months.
Andy
   / Chipper Blades #5
I watch the hour meter on my chipper and sharpen them around 40 hours. I have gone to 50-60 hours. That is getting a big too long as it is harder on the chipper. Also I rotate the anvil to have a good clean edge for the wood to be sheared when the knife comes down. Gap is another important thing.
   / Chipper Blades #6
On my manual feed Bearcat chipper/shredder I get 10 to 15 hours before it gets hard to push the wood through.
Chris
   / Chipper Blades #9
10 or less usually. Whenever the chipper stops self feeding and starts "tearing" the wood instead of "shearing" the wood. Usually the bark starts peeling off the wood in strips too instead of being cut with the chips.
   / Chipper Blades #10
On my Morbark chipper I run around 10-20 hours on a set of knives before rotating.
I kind of keep a mental note on what I have been running through the chipper, and keep track of the hours via the hour meter.
Keeping the gap adjusted with respect to the anvil is also very important.
If I have even the slightest notion of any metal in the wood, I will set it aside for a burn pile.
It seems to me that a piece of rebar going through a chipper can get very expensive.
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
