Chipper Chipper - hydraulic feed or no?
   / Chipper - hydraulic feed or no? #1
tuolumne
Danby Vermont (soon)
I am clearing 2+ acres of hardwoods this spring, and am debating a chipper purchase. It will be used occasionally over the following years as firwood is harvested and additional property is cleared for pasture etc. Anything over 3" will be used for firewood, so I don't need anything too big. I was quoted for a Wallenstein BX42 pto chipper. I would certainly want something like this with a chute to eject chips. Has anyone worked this chipper enough to know how it performs long term? What is the hydraulic feed option worth to those who have used this. My only experiance with chippers is on huge stand alone rentals that can suck up 8" logs like nobodies business. If you don't let go fast enough you'll get a ride. How fast do you wear down when manual feeding? The last thing I want is to be sapped when picking up the chainsaw or operating this powered arm grabber. Do the blades tend to pull in the branches, or does one need to push the whole way.
   / Chipper - hydraulic feed or no? #2
I don't know the Wallenstein but I have a Jinma 6" chipper with a mechanical feed. The feed roller does the work in pulling through anything under 3". Larger stuff I have to help sometimes but the worst offenders are trees or branches with stiff 4 - 5" side shoots 1" or larger in diameter which won't bend flat. These can hang up on the roller. I know now to make feeding easier to cut side branches right against the trunk when I limb.
Even with the mechanical feed, operating the chipper is still a workout because there's a lot of lifting and pulling, teasing out trees and branches from the piles, then getting them up and into the feed chute. When trees and branches are 12 - 15 feet long and 3" at the thick end, this takes some work. I find this is where the bulk of my energy is expended, not in teasing them through once they're in there.
I try to plan my day's tasks so I don't do any more than a couple hours of chipping at any one time. I find something lighter to do for a while then go back to it.
   / Chipper - hydraulic feed or no? #3
I, too, have been thinking about getting a PTO chipper/shredder for my L3130. My only fixed requirement is to have some sort of automatic feeding mechanism. I currently have a hand fed gas powered chipper, and man that thing beats the s**t out of me as much as the wood it's chipping! It's not so much the work of pushing the wood into the chipper as it is the vibration you feel through the wood as it's ground up. After a few hours of that ALL my joints ache like no one's business. Even on smaller stuff (I also keep most everything for firewood and only chip stuff an inch or less in diameter), it's real rough on me. So my only advice would be definitely buy something with automatic feeding, you won't regret it.
   / Chipper - hydraulic feed or no? #4
Remember safety first when using these things...
Last week I hired a crew, to do some chipping for me, price was 4 guys, and a chipper @ $100.00 per hour ( I'm is Southern Ca.), and one of the crew guys was ON the chipper kicking things in - then the next day I read this, an accident that happened somewhere else.
A 30-year-old man was killed when he was sucked into a wood chipper while trying to shake loose a piece of wood that had jammed it.The man owned a tree service company working in the 8900 block of 26th Ave. in Pleasant Prairie, according to a Pleasant Prairie Police Department press release.The man was using his foot to clear debris that had jammed the wood chipper around 5:20 p.m. when his foot became entangled in the machine, witnesses told police.His coworkers tried to rescue him from the intake, but he was pulled into and through the wood chipper, according to the release.The incident remains under investigation by Pleasant Prairie detectives, the Kenosha County Medical Examiner's office and officials from the Occupational Safety and Health Administration.Police withheld the man's name while they attempted to notify his family.
He disconnected a the feed wheel control bar, because it was sticky/malfunctioning. This unconscionable act made it so that his crew could not help him and had to watch him go through, the customer live with the thought of what happened on his property, and municipal workers with examination and cleanup.
   / Chipper - hydraulic feed or no? #5
Not sure the PTO hp you are running but for a 4" chipper you should have about 25 or PTO. I run a wallenstein 6" off a l4330 something like 38 PTO hp and the thing eats 6" sticks no problem.
I have the manual self feeding version bx60 it cost me around $2500 defenitely a workout and have thought about getting a hydro unit, but can't justify the approximate $6000 price tag. If you can swing the extra $3000 go for the hydro unit you will not be disappointed. I pwersonally would stay away from the belt driven units. If it is a once and a while thing get the manual feed and keep the knives sharp.
Mike
   / Chipper - hydraulic feed or no? #6
For me and all the many helpers that have used my old Morbark chipper, hydraulic feed is VERY worth the extra $.
   / Chipper - hydraulic feed or no? #7
Get somthing that feeds automatically, it's going to be a real timesaver.
I used a Troybuilt chipper one summer and there is no comparison to the amount work you can get done with an auto-feed.
   / Chipper - hydraulic feed or no? #8
I have sold hundreds of the Jinma woodchippers,the belt driven feed roller will pull in 1"-4" stuff with ease,they are a great value .No doubt a hydraulic feed unit is the cats meow but do you need it for what you are doing 2 acres?Is it worth $ 4,000. more than the Jinma ? There is alot of information on this board about woodchippers with customer comments,do a search on them.
If you did need a part for the Jinmas they are a phone call away.Two weak points are the knuckle on the feed driveshaft and the feed belt,both are less than $ 20.00 to replace
Tommy
Affordable Tractor Sales
Sounds like my best bet is to rent a pull behind chipper for the day and get some help. This would be by far the cheapest option and the easiest to do the work. However, I know I'll never again rent one over the years as needs arise for small amounts of work. If I owned one it would see frequent use like this. I'd rather be making mulch than smoke. What a dillema!
   / Chipper - hydraulic feed or no? #10
Not tractor powered chippers but,,,,,I've owned two different gas powered homeowner type chippers. One was an MTD 5HP and would eat up to 2" and a Troy Bilt 8HP for 3" limbs. The MTD had two cutting blades on the flywheel. The TB had one. I learned with the first one (MTD) that if you keep the blades razor sharp it would pull the stuff in on its own. The TB was always difficult and had more vibration due to one blade.
Both were a bit of a pain to remove the blades to sharpen.
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
PALLET OF (2) THERMOKING TRI PAC UNITS (A50854)
PALLET OF (2)...
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
