I went over this exact same contemplation last year. 4 things swung me to the PTO unit. #1 Price a bobcat
chipper new is almost $8000 as you would need the 8B
Chipper to do the size you need, and the Wallenstein BX42 was around $2800 (This comparision is a little unfair as the wally is not self feed, wish it was. Now as said the bushy stuff take some muscles to feed. Oh well). #2 Fuel, My Bobcat T750 85 HP can go through 20 gallons of Fuel in 8 Hours no problem, where the deere 2032r will only sip probably about 5 gallons. #3 Weight, we have a some low wet land that we are cleaning. A 100 HP track loader or skid steer will be in the 10,000 LB range before the
chipper at an aditional 1600 LBs. Where the tractor loaded rear tires
chipper and loader come in around 3500 LB's. I try and stay out of the wet stuff but even when dry i want as little as impact as possible, the CTL does float pretty well but it still can go down easy i prefer the tractor. #4 The skid steer at 85 HP has a lot more lifting capability's than the tractor, so i mostly have the grapple on the skid steer to move, rip out the brush and trees. The wallenstein chippers the way they are set up with the angle on the chute are fairly compact compared to the bobcat design on the
chipper, which is similar in design to several of the import pto chippers, once attached to the skid steer it is fairly long as well. In all reality you can get a wally in most tight spots. Now there are several good reviews on the
woodmaxx chipper which is a good priced unit with hydraulic feed that may be an option for you. I like the simplicity of the wally
chipper the old KISS statment makes maintaince and repairs easy. I'll put a little more labor to stuff the feed chute for the reliability, and dependability of the product personally. That was my thinking on this subject.
Here is the asking price on a used Bobcat
chipper size unknown.
skidloader wood chipper
