City boy moving to the country
   / City boy moving to the country #1
Mike Travis
Columbus, OH
Ford 860
Hey all,
We recently bought some land in the country where we intend to move. It is small (less than 30 acres) and we plan to become self-sufficient by raising animals and crops, along with bees. Being I have never lived in the country nor planted crops, any advice you are to give would be greatly appreciated. :confused:
We just bought a Ford 860 with a 4 gang disc. Intend to add some type of plow along with a cultivator. I am finding it difficult to locate a website that would help a dumb city boy learn to prepare the soil, plant, maintain, and harvest, so if there is such a link here or somewhere else, I'll gladly buy you the beer of your choice.
Thanks,
Mike
   / City boy moving to the country #3
Now: How much of your 30 acres will you crop? How much pasture?
Is the land flat or sloped in the crop and pasture areas? How sloped?
What are you intending to grow as a crop?
Do you have gravel/earth private drive to maintain?
Will you be cutting firewood for heating on your property?
Will you be putting in wild game food plots?
Have you prior tractor experience? Will you service tractor yourself?
jeff9366
Thanks for the reply.
We are only going to start on 1/2 acre to 1 acre max this season. Pasture will be limited as we do not intend to have cattle but goats, chickens, and rabbits. In the future we may raise pigs but I don't want to bite off more than I can chew. With that said about 10 acres is all that is tillable. Slope is minimal though I can't say what the degree is. We have a piece picked out that is relatively flat with good drainage off 2 sides.
We are planning to plant sweet corn, beans, squash, spinach, carrots, and beets.
Yes, we have a earth/gravel drive to maintain.
We will have firewood as a supplemental heat source to LPG. Plan to use both and dress warm.
There is wild game in the area though we are not planting for them. We will be wanting to keep them out of the crops, especially the deer and rabbits. Ideas or suggestions on that would be welcomed.
I do not have tractor experience though I have maintained my cars and motorcycles since I was 14. I do intend to service our tractor myself. We are getting a manual to help with that.
Thanks again.
   / City boy moving to the country #5
Mike, I like your ambition and vision. Good luck with your pilgrimage from the city to the farm! :thumbsup:
   / City boy moving to the country #8
Mike,
Welcome from Grove City Ohio, just south of Columbus
   / City boy moving to the country #9
We are only going to start on 1/2 acre to 1 acre max this season. Pasture will be limited as we do not intend to have cattle but goats, chickens, and rabbits. About 10 acres is all that is tillable. Slope is minimal. We have a piece picked out that is relatively flat with good drainage off 2 sides.
To start cultivation there are two ways to go.
1. "Open" ground with a Moldboard Plow, preferably in the late Fall, then, in early Spring, break up the deep furrows and clods left by the plow with multiple passes with a Disc Harrow, then drag to flatten further, then sow and roll in seed. If you intended to cultivate 20+ acres for cash crops this would be the way to go.
2. For your half to one acre this year, with incremental annual growth, a tractor Three Point Hitch mounted, Power-Take-Off (PTO) powered Roto-tiller is the route to go. One or two passes and you will be ready to plant veggies. Roto-tillers for small tractors come in sizes from 42" to 84" wide. (Roto-tillers and Disc Harrows are both tillers.)
You will want a tractor with a Front End Loader (FEL) which you can think of as a powered, elevating wheelbarrow.
This is the most common small tractor option. Almost everyone who writes here has one on their 20-50 horsepower tractor. Most tractors with an FEL also come with Four Wheel Drive (4-WD) for traction, which is necessary to fill the FEL bucket. FEL is used to move soil, dung, firewood, harvested crops, building materials, tools, fertilizer, etc. A great productivity multiplier.
The smallest tractors are called sub-compacts. (SCUTS). Most here would agree they range 16-20 engine horsepower, have nine inches ground clearance and usually a two-speed semi-automatic Hydrostatic transmission. (HST).
The next larger tractor category is called compact utility tractors (CUTS). CUTS have 20-45 engine horsepower and the most common size of Three Point Hitch (3-PT), a Category '1'. CUTS have 12" - 14" of ground clearance. This is the category of tractor you will want. You will need to do a lot of research to decide on how heavy and how powerful a tractor your needs require and what you can afford.
If your gravel drive is in good shape you may be able to maintain it with only a Ratchet Rake attachment on the FEL bucket. For your garden, in addition to a PTO roto-tiller you will need a one row or two row cultivator.
From here, the list of useful bucket attachments and 3-Pt implements used in farming is infinite.
Observe what farmers in your area use to keep deer out of their crops. I am retired from the California wine industry. Where we raised wine grapes in hilly areas, ten foot fences were required to keep deer out. On flat land perhaps lower fences would suffice.
Ask tractor questions in the OWNING & OPERATING Forum.
Good luck.
LINKS:
TractorData.com - Three-Point Hitch
Iowa Farm Equipment -- Rotary Tillers & Power Harrows
Tractor Cultivator 3 Point Hitch, Single Row & Field Cultivators for Cultivating Potatoes, tomatoes and other crops
http://www.lsuagcenter.com/NR/rdonl...45263BDD8/11557/pub2917tractorimplements1.pdf
http://www.tractorbynet.com/forums/...ons/312467-need-help-selecting-tractor-2.html
Thanks for the warm welcome from everyone. I do appreciate it.
And thank you jeff for your detailed answers. It is very helpful for this city boy as I have a lot to learn.
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2000 Witzco Challenger RG-50 48FT 50 Ton Tri-Axle RGN Lowboy Trailer (A52377)
2000 Witzco...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
199049 (A51243)
199049 (A51243)
