CK20 How big of a post hole digger?
   / CK20 How big of a post hole digger? #1
Agentiron
Northwest Indiana
How big of a post hole digger can I run on a ck20 in heavy clay? I would like to have at least a 12" auger. Any reccomendations on a brand that gives me a variety of auger's both in diameter and length? I really need to go at least 3 foot.
AI
   / CK20 How big of a post hole digger? #2
I just picked up my Gearmore D20 with a 12" auger last Friday. I have not had a chance to mount it and try it out, but it looks very well made.
   / CK20 How big of a post hole digger? #3
I bought a midium duty post hole digger with a 8 inch auger and it works great have not trie a 12 inch auger as of yet. and welcome to TBN.
   / CK20 How big of a post hole digger? #4
My PHD uses a shear pin, and with the 8" auger i have replaced 3 pins....all the result of hitting rockzilla(s). I don't think a 12" is a prob, but you may shear more pins depending on what type of soil you are digging into. I wish i had a slip clutch like on my brush hog, but i havent seen a digger with that feature.
RD
   / CK20 How big of a post hole digger? #5
I think you can add a slip clutch to most phd's as an after market. I thought about it. But, pins are easy to replace and for me it just hasn't happened often enough to justify the clutch. Now, if I had a bunch rock to drill into, the clutch would be a welcome addition.
   / CK20 How big of a post hole digger? #6
I have the PHD from TSC. run both a 6" and 12" in medium clay/loam. Haven't sheared a pin yet, but I only run 1/4 throttle max.
Yes ,you can add a slip clutch easily, TSC has both 6 spline male/female and 6 spline/round shaft so they can be used either way. Price is reasonable.
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
2025 LandHonor UHA-16-3000G 2in Utility Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
4 Door Hutch (A49462)
