CK30 range lever
   / CK30 range lever #1
Ford 1720 TX
Bastrop, TX
Ford 1720-destroyed in flood. Kioti CK30
I have a 2014 CK30HST that is having a problem with the range lever.
The tractor won't go into low range.
The lever seems as though it's slipped a notch.
Low position is neutral.
The next neutral position is medium
The Medium position is a neutral
The next neutral position is High
Is this anything you've heard of before?
Thanks for any reply
   / CK30 range lever #3
Follow the linkage back under the tractor. I vaguely remember a place to adjust it. But be safe and have the tractor blocked so it wont move.
   / CK30 range lever #4
mine did the same thing turned out that a adjustment was needed and also the indicator label was positioned wrong when I thought I was in low I was in medium and so on
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2007 PETERBILT 379 (A52472)
2007 PETERBILT 379...
New Long Forks (A53002)
New Long Forks...
2019 RAM 3500 (A52472)
