CK30 squeak
   / CK30 squeak #1
harleyboy
Bronze Member
alvinston ontario canada
Kioti ck30hst
Guys
My CK30 HST sudenly has developed a squeak in the front some where? I thought it was the hydraulic issue that has been talked about but don't think so what do you think?
It comes and goes but is louder in reverse. I jacked up the front right wheel and when turning the wheel by hand the squeak is coming from the drive shaft???
HB:confused:
   / CK30 squeak #2
Have you checked the oil level in the front axle? Sounds like it may be a bad pinion bearing as the drive shaft is just a spline shaft held to the pinion with a coupler and cer clip. You can remove the bolt holding the drive shaft tube to the front axle and slide it back and then do what you did before to confirm if that is where the "squeak" is coming from or not.
   / CK30 squeak
Thanks DirtHauler
I will try that, I called my dealer 1 hour away and the mechanic said to keep an eye on it and not to worry if it gets worse they will fix it.
It just bugs me.
HB
   / CK30 squeak #4
Check the torque on the lugnuts front and rear.
BTI
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
