Sprayer Cleaning Sprayer Tank
   / Cleaning Sprayer Tank #1
Flyindutchman
Bussey, Iowa
Mahindra 2538 HST
Just curious as to what most of you use to clean your sprayer tanks.
   / Cleaning Sprayer Tank #2
When it gets cleaned I use ammonia. I will wash it out going from Gyposhate to broadleaf herbicide but in reverse I just flush with water .
   / Cleaning Sprayer Tank #3
Water flush is all that is necessary with most chemicals.
   / Cleaning Sprayer Tank #4
I just flush the system with water most times, but occasionally add a squirt of dish detergent.
   / Cleaning Sprayer Tank #5
Guess that I put about ten to 20 gallons of water in it and then run the pump until it's dry. About half of that will be through my wand, then the rest through the sprayers.
   / Cleaning Sprayer Tank #6
I do the same as Eddie-fill my 25 gallon tank 1/3 to have full and let it pump through broadcast and wand.
   / Cleaning Sprayer Tank #7
TSC and other places will sell a tank cleaner to neutralize any chemical. In the past I have just rinsed with water but I bought the cleaner this year now that I'm switching between Gyposhate and Trimec. I have not used it yet, but I saw it for cheap and I believe one jar will outlast me.
   / Cleaning Sprayer Tank #8
Mine has a turbo "mixing mode" So a shot of dishwashing soap - ten gallons of hot water - let it "turbo" for ten minutes or so. DO NOT forget to leave lid off - I shut it down when suds start to overflow
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
DMI 13' Chisel Plow (A50515)
DMI 13' Chisel...
2011 Liebherr L586 (A52128)
2011 Liebherr L586...
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
UNUSED JCT DUSTLESS BLASTER (A51244)
UNUSED JCT...
Brent 644 Gravity Wagon (A52128)
Brent 644 Gravity...
