Clocking of mower blades
   / Clocking of mower blades #1
tmshort
Bronze Member
Indiana
Just swapped out the stock blades on the MMM for a set of Gators.
I was wondering ... is position important? It is not mentioned in the manual, and there is no tab or anything else on the attachment point to index or "clock" the blades.
I put the new ones on in as similar a position to the priors as possible, but was wondering if they could be put on in any position.
T.
   / Clocking of mower blades #2
If the new blades are all the same length no indexing required, if spindles are belt driven index all you want they will never stay that way.
Thanks.
They are all the same blade.
I didn't think about the belt issue ... that makes sense.
Interestingly when I flipped the deck today they were all perfectly aligned in the same direction ...
T.
   / Clocking of mower blades #4
My Kubota ZD has a diagram in the manual showing the position the blades should be at when installed. I did it a few times but figure like you guys, they won't stay like that for long.
   / Clocking of mower blades #5
The only mower blades that need "timed" are ones with a gearbox drive instead of belts.
Greg
2017 ISUZU NPR 16FT BOX TRUCK (A54607)
2017 ISUZU NPR...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A55218)
2018 Link-Belt LBX...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
