Clutch alignment tool TC40a 16 spline
   / Clutch alignment tool TC40a 16 spline #1
MVTractor
West Tisbury
2005 New Holland TC45A boomer
looking around the web and can't find a clutch alignment tool for this project, Should be 16 splines 9 1/4 disk diameter hole is 1' 1/16 may be off by 1/16" for a SBA 320040930R clutch This is aftermarket # Understand it can be done without but need to be sure. Thanks
   / Clutch alignment tool TC40a 16 spline #2
It can be easily done WITHOUT a clutch alignment tool.
Have done it TWICE on my Ford 1920.
I understand that you can partially insert the spline then tighten the bolts, just a little concerned because I am not doing the project and thought if a tool was available it would be helpful If you have a better way would love to know thanks Don
   / Clutch alignment tool TC40a 16 spline #5
I done a clutch alignment by shining a light down the splines and tapping the pressure plate which ever way needed to center it. Just lightly tighten the pressure plate bolts to hold the clutch plate in place. Once the clutch disc is aligned the pressure plate bolts can be evenly tightened down.
If you buy a universal type alignment tool you need to do the same as above and move the tool in a circle as it won't be a snug fit. The idea is to find the center of the circle with the tool before you tighten the pressure plate bolts.
   / Clutch alignment tool TC40a 16 spline #7
Any decent universal clutch tool will have a tapered centering bushing that will locate the disc concentric with the pilot bearing. The key is having a bushing to install on the arbor that matches the pilot bearing’s bore. If not, electrical tape can be your friend.
   / Clutch alignment tool TC40a 16 spline #8
I never thought of using tape nut that would work too.
Thanks all, Will relay info to my mechanic though I think this may be the least of my worries cause after two months the slow boat to China has finally left the dock.
   / Clutch alignment tool TC40a 16 spline #10
2019 Freightliner (A45336)
2019 Freightliner...
Takeuchi TL8 Skid Steer (A47809)
Takeuchi TL8 Skid...
2015 Chevrolet Tahoe 4x4 SUV (A45336)
2015 Chevrolet...
2018 Chevrolet Equinox 1LT AWD SUV (A46684)
2018 Chevrolet...
2013 Ford Escape SUV (A46684)
2013 Ford Escape...
2025 Kearney 76"X16' Trailer (A47307)
2025 Kearney...
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
Please support our site by disabling your ad blocker.
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
