The plates tend to rust or freeze together while being stored for longer periods is what I understand. Which would keep you from disengaging to start your tractor. There are more folks out here that can explain it a lot better.
Same thing happens to parking brakes. Best to disengage them when storing the tractor for months. Be sure to chock the wheels instead of setting the parking brake.
Lotsa tractors come from the factory with a wood wedge for keeping the clutch blocked for periods of non use.
soundguy
Sounds like an old wive's tale to me.
Ralph
The clutch facings aren't metal to metal are they? Most clutches would only contact the clutch wear surface material (similar to brake pad material) against the steel pressure plate. What's to rust together? Won't happen unless the clutch wear surface is worn away enough to where the rivets or attachment devices (may be glued in place like brake pads now) are in contact with the pressure plate.
Ralph
soundguy
Poor Ralph!
Is this worse in places where it is cold than in warmer areas?
Never did this in storing my Benzes. The 1973 was stored in our garage for 9 months. Just took the battery out. It started instantly when battery was put back in place upon our return. Our 1983 was stored in the garage for 4 months. No problems. It was again stored for 4 1/2 years. The clutch took a few strokes to work (a year later had to replace the clutch master cylinder; suspect it was bypassing, needing stroking to get it to seal; brake master cylinder do this, too, when they start to go).
Ralph
