CLUTCH PRESSURE PLATE VS INTERNAL CLUTCH PACKS
   / CLUTCH PRESSURE PLATE VS INTERNAL CLUTCH PACKS #1
Mike187d
CA San Joaquin
Yanmar 187D
I own a Yanmar 187D tractor w/ ~365 hours of run time. When warmed up the clutch appears to slip. I have plenty of freeplay in the clutch pedal. I don't smell anything resembling a slipping clutch. Thinking it may be the internal clutch packs I changed the transmission fluid and filter and cleaned the screen but didn't make a difference.
Is there a simple method of identifying the problem? Thanks
   / CLUTCH PRESSURE PLATE VS INTERNAL CLUTCH PACKS #2
Mike,
Excessive free play may indicate a problem if gears tend to grind when shifting. T/O bearing travel is dictated from 1/2" to 3/4" pedal travel to fully engage-disengage clutch disk.
Any trouble shifting when RPM's over 1000?
BTW, Welcome to TBN
Regards, Mark
   / CLUTCH PRESSURE PLATE VS INTERNAL CLUTCH PACKS #3
I have a YM1110D with the powershift transmission. Here is how I checked to see if my internal clutches were slipping. Since the regular clutch also engages the pto, I just put the tractor and pto in gear and began driving. Then I pushed the brakes hard enough to stop the tractor from moving, and then checked to see if the pto was turning. It was turning, while the tractor was not moving. That meant that the internal clutches were slipping, not the regular one. But in doing this, the engine lugged down alot, and began to smoke. So I figured that was a heavier load than I was ever going to put on the drivetrain.
I think you are on the right track. If the internal clutches are slipping, then either the clutches are worn out (I haven't heard of anyone replacing them yet) or they are not getting enough hydraulic pressure. The most common problem is leaking o-rings in the hydraulic shifting mechanism (which is really a fancy hyraulic valve) not allowing enough pressure to the clutches. Hopefully, someone else with more experience can provide some better information.
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
