Clutch seems like its low on fluid
   / Clutch seems like its low on fluid #1
Banjo22
Raceland, La
ISEKI TS1910
I am new to the world of tractors. When I go to switch gears it seems the clutch isn't working just right. There should be some kind of fluid to check and replace for the transmission right? Where is that and what type of fluid should I put. Also when the PTO is engaged and I press the clutch in, I cannot switch gears until the bush hog is done spinning.....is this normal?
   / Clutch seems like its low on fluid #2
That model doesn't have a hydraulic clutch so there isn't any fluid to check ( just shared trans/ hydraulic fluid shared in the transmission. You may need to make an adjustment on the pedal. Follow the linkage from the pedal and there should be an adjustment for clutch engagement.
Not uncommon for the shifting/PTO issue. That model doesn't have a live PTO ( 2 stage clutch) A live PTO works with the use of a two-stage clutch. Pressing the clutch half-way will disengage the transmission while pressing it fully will disengage the transmission and the PTO. This allows the operator to slow down or change gears while the PTO is still operating.
An overrunning clutch is often needed with a transmission PTO. Without it, the driven equipment (such as mower blades) will put a force on the PTO shaft, and then the transmssion, due to inertia. The equipment will "drive" the tractor, and you will still move after using the tractor's transmission clutch. An overrunning clutch prevents this from happening by allowing the PTO shaft to freely spin in one direction. In more recent models, this is built into the tractor. In older tractors, it is an extra piece of equipment mounted on the PTO shaft.
Ok,
My tractor does in fact have an overrunning clutch, however when my blades are free spinning after I push the clutch in, I have to wait until the blades come to a stop before I can change the transmission gears...does that make sense? Also while your here...Does the Trans/Hyd shared take Trans or Hyd Oil? BTW I will be working the tractor this weekend and will update with adjustments.
2006 Chevy Trailblazer (A47384)
2006 Chevy...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
2016 Ford Fusion SE (A50324)
2016 Ford Fusion...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
