Clutch
   / Clutch #1
samacdon
Farm pro 2420
Having clutch issues with my Farm pro/ Jinma 2420. I have gone through clutch adjustment which i understand as being 10mm between the clutch release finger and the release bearing (please let me know if this is wrong). I'm trying to find the right clutch for my tractor. My question is can i substitute a 6 finger clutch for a 3 finger?
   / Clutch #2
The instructions I have for a 2006 284 with two stage clutch is that the fully released pedal should have a 2.5 to 3.0 mm clearance between the throw-out bearing and the clutch fingers. This should give you 3.5 to 5.0mm of "free" travel at the end of the rocker arm where the clutch push rod attaches.
What kind of clutch issues are you having?
What year tractor?
Dual or single stage clutch?
I can't answer the question about 3 finger and 6 finger interchangeability, but my instinct is to say no. Without knowing all the specs for each clutch it would just be a guess. Things like, bolt pattern, dual or single, Height of clutch pack assy. Diameter of disc and plates. Size and spline count of the transmission input shaft and several other things.
2025 Dig Master DM100 UNUSED Mini Excavator (A47484)
2025 Dig Master...
2013 Ford F-150 Ext. Cab Pickup Truck (A44572)
2013 Ford F-150...
2016 International WorkStar 7400 T/A Forestry Grapple Truck (A44571)
2016 International...
American Sanders Floor Sander (A45336)
American Sanders...
2012 AMERITRAIL, INC. 30 T/A GOOSENECK TRAILER (A45046)
2012 AMERITRAIL...
2017 Nissan Titan Crew Cab Pickup Truck (A44572)
2017 Nissan Titan...
