Coil gone on HRR216
   / Coil gone on HRR216 #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Anyone else have their ignition coil on their Honda HRR216 go after only 3 years?
Wouldn't start for the wife today. She ran the battery down then went to pull start. Started but then quit after just a little bit.
I checked for spark with an old timing light. Did not light up. Guess the ignition coil is bad. Looks like a $35-50ish item online. Bought it at John Deere. Will give them a call tomorrow morning.
Ralph
Noticed that the starter would work with the coil off.
Crud on the coil apparently was shorting out signal to starter and maybe some primary voltage.
Cleaned crud off with air then carb cleaner. Put back on. Started up.
Note to cancel order for coil tomorrow. Keep order for new spark plug and air cleaner.
Ralph
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2017 Miller Nitro 6300 Self Propelled Sprayer (A50657)
2017 Miller Nitro...
2013 DOOSAN G25P FORKLIFT (INOPERABLE) (A50854)
2013 DOOSAN G25P...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
