Cold leak down.
   / Cold leak down. #1
atk_man
Duncan, BC, Canada
1979 Kubota B7100D
The temperature has dropped here lately and I've noticed something on my '79 b7100. What I usually do before I start working is get the tractor running, then back it out of the barn (about 20 feet or so) to let it warm up. What I noticed the other day is that when I lift the FEL after starting it cold, it was very slow to move. Also, once I stopped lifting, it dropped as fast as it lifted about half as far as it lifted. After going up and down like this a few times (and warming up) it stopped dropping and started moving faster again. Once warm, the FEL is solid as a rock, it never dropped.
Is this normal for an older unit? It only has about 525 hours. The lift rams do "weep" a bit. Also, I had just topped up the fluid (maybe a bit too much because some blew out when it warmed up)
Is this a function of temperature (it was about 32 degF) or air or water or seals?
Any Ideas?
Thanks in advance.
Henry.
   / Cold leak down. #2
Never had that problem w/my B7100 w/FEL...yet.I let mine warm a good 10min at 1/3 throttle,than raise the FEL 5 or 6 times also rotate the bucket 5 or 6 times be for engaging transmission....also I plug in the block heat hours before use.Warm hyd fluid easier on transmisson..filters..etc...
   / Cold leak down. #3
Henry, sounds like the cylinder seals are a little worn, but if everything is "solid" once it's warmed up good I would'nt sweat it too much. The colder temps are just "anouncing" the problem. Probably would'nt hurt to have the boom (loader lift) cylinders repacked in the future.
Ford Tractor (A50120)
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
19104 (A51694)
19104 (A51694)
198367 (A51243)
198367 (A51243)
2007 Ford Taurus Passenger Car (A51694)
2007 Ford Taurus...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
