Cold weather starting of 1300D
   / Cold weather starting of 1300D #1
lowveld
I have a 1300D without Thermostart. It sometimes gets into low 20's F degrees where I live.
What is the likelyhood that I can start the 1300D engine without a Thermostart at that temperature by using compression release until oil pressure light goes out, then opening throttle and attempting to start the engine?
Best Regards;
Lowveld
   / Cold weather starting of 1300D #2
Do you have electric at the tractor? You could use a block warmer, radiator cap warmer or even just a battery warmer may help too. I live in NE ohio and never had a problem even without thermostart on a 1500 I have. If the battery was warm there was enough crank to get the needed compression.
Peter
   / Cold weather starting of 1300D #3
It won't start when it's that cold. Even with the thermostart system it's rather marginal. These are definetly warm weather engines! If you have a battery charger handy you could see if the engine will spin fast enough to make a fire but I doubt it. The best solution I can see is to find a in-line engine heater. The getcha is that the heater will want to be mounted in the lower hose, and I don't know if you have a straight length that will work. Option C would be to give her a little squeeze of either. Don't go nuts, but the engine will take a little shot while it's spinning. I don't know if you'll have to pull the air cleaner or not.
   / Cold weather starting of 1300D #4
I suggest a block heater and good battery charge. I know a lot of people have used ether/starting fluid on these small engines ( I'm one of them) but I recommend you not do it. I think the risk outweighs the benefit, I have heard too many stories about small diesels that are being rebuilt from the effects of too much starting fluid.
If you do ever feel like there's no other way, maybe giving it a small shot while already spinning, like Cord suggests, helps....but I'd go to great lengths not to try it.
Gentlemen;
Thank you for your observations. I will see what happens when winter arrives and determine if I will have to add a block heater.
Best Regards;
Lowveld
   / Cold weather starting of 1300D #6
I have thermostart and I've been able to start my tractor in -5 degrees F. I haven't had a need to start it in anything below that but 2 years ago we had a big snowstorm on Feb. 13 and the next morning that is what the temp was when I started clearing the 4-6 foot drifts out of my driveway. It was so bad that all of us who had tractors just cleared ourselves out and went neighbor to neighbor to help those who didn't have one (just got together and said ok, i'll do so-and-so, you get that one, etc. It took all day to get us all cleared out.) So these things can be started in very cold weather. If you don't have thermostart a block heater should do the trick. You should probably plug it in at least 3 hours before you need the tractor and tarp it or something to keep the heat around the tractor.
   / Cold weather starting of 1300D #7
I have a 1500D and where I live in Utah we get more than a few -10 mornings. I have never had a problem starting the tractor to move snow.
Hustler Raptor Zero Turn Mower (A53117)
Hustler Raptor...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2005 Carolina Skiff 21DLX 21FT. Boat with 23FT T/A Boat Trailer (A51694)
2005 Carolina...
1997 Ford F-250 Pickup Truck (A53117)
1997 Ford F-250...
2020 INTERNATIONAL LT625 DAY CAB (A53426)
2020 INTERNATIONAL...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
