Compact tractor sizing
   / Compact tractor sizing #1
Michael Aos
Colorado Springs
Kubota BX2370-1 RTV500
I understand certain planned activities will push the sizing one way or another, but I still think there is a relationship between tractor size and acres.
I was thinking something like this:
1-3 acres - BX
3-5 acres, B01
5-10 acres, B50
10 acres+ L
Sound about right?
   / Compact tractor sizing #2
Not Bad. I think the L could sneak into the 5-10 acre category depending on.
Here is the Green version or what you say
Acreage............. Kubota ..........Deere
1-3 acres ..............BX................1xxx.......SCUT
3-5 acres,..............B01..............2xxx .....Small Frame CUT
5-10 acres............. B50.............3xxx ....Mid Frame CUT
10 acres+............ L Grand..........4xxx
...Large Frame CUT
   / Compact tractor sizing #3
I have 5 acres & my L3200 was pretty good. A B might be enough, but i think it would be to small for my needs on 5-10 acres. The Grand L is a LOT more tractor than an economy L even if the L3200 is only 3 HP less than a L3560.
I upgraded to a cabbed L4060 & justifed getting the nicer cabbed machine by doing side work. I can mow 5 acre lots of rougher field in an evening after my day job, even before the upgrade. Would be rough ride & slower with A B.
The 3000 series JDs are physically smaller than a L3560 or L4060, but have equal or more HP. Good for mowing heavy grass & manuverability, but not for lifting or pulling. The 4000 series JDs are noticably bigger & heavier than the Grand Ls. When looking at the premium 3000 series JDs compared to a Grand L the JDs were several grand more for less tractor with equal HP, lots more for more HP.
   / Compact tractor sizing #4
1-3 acres - BX
3-5 acres, B01
5-10 acres, B50
10 acres+ L
Sound about right?
I don't think so. I've had several BXs, Fs, Bs and a couple of Ls. Size implements and use are more determining factors than size of property. :2cents:
   / Compact tractor sizing #5
Yes. What he said.
   / Compact tractor sizing #6
Actually not. The L6060, for example, outspecs the 4720 in weight, wheelbase, 3 point capacity, etc. For day-to-day work though, the Grand L's and 4000's would work at essentially the same level. They compete nose to nose.
   / Compact tractor sizing #7
I've got a L4060 & all the Grand Ls except the L3560 are the same frame. I'm pretty sure the JD was a fair bit heavier & more expensive (even the economy model) than my Kubota when I was looking a year ago.
   / Compact tractor sizing #8
My BX25D is plenty sufficient for my 5 acres (and garage size). I use mine to mow, trench, snow plow, and attack/move scrub oak. I have a wicked root compact grapple, snow blade and a 60" belly mower. I needed a back hoe for trenching more than I needed a bigger tractor.
   / Compact tractor sizing #9
Well, IF I had 3 acres and I was doing anything besides cutting grass, I sure wouldn't want to be stuck with a BX!
SR
   / Compact tractor sizing #10
Such a difference isn't showing up in the published specs presented on the Kubota and Deere websites:
http://www.kubota.com/product/LSeries/L60.aspx
John Deere 472 4;) 4 Series Compact Utility Tractors
Using the largest models (L6060 and 4720):
Kub 6060 JD 4720
Weight (no cab): 3,990 lb 3,700 lb
Wheelbase: 75.4" 71.5"
3pt lift at 24" 2,976 lb 2,500 lb
Engine: 148.5 Cu in 148.9 Cu in
62.0 hp 66.0 hp
Comparing your 4060 to the equivalent 4120 shows the same thing: your 4060 weighs 3,759 lbs, just a hair more than a 4120 at 3,700 lbs. I figure you got at least as much tractor as Deere has available in the 4 series at 42-43 hp.
Wouldn't doubt that the MSRP prices differ.
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
