Jun 20, 2013 / Compatible trans/hyd oils.....? #1 TAZ DEVIL New member Joined Jun 20, 2013 Messages 3 Location Michigan Tractor JD 300, NH T1510 I can't seem to find correct cross match chart on line. does any one know if JD20C is compatible to Ambra G 134 thanks for any input
Jun 20, 2013 / Compatible trans/hyd oils.....? #2 Soundguy Old Timer Joined Mar 11, 2002 Messages 51,575 Location Central florida Tractor RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC best bet is too look at the pail of utf you are wanting and see if it meets the specs for your machines. ie.. jd20c and m2c134d etc. there is a updated CNH oil past the 134d spec.. etc..
