Complicated but hear me out.
   / Complicated but hear me out. #21
The bush hog isn't hard to add or remove. I do it on a regular basis to swap out with my tiller. I set the front end on 4x4 blocks which allow me to slide it around a bit. I just got a quick hitch from Harbor Freight for Christmas, and hope it will make swapping the mower for the tiller even easier. I would think the backhoe would be the challenge, especially if it is a frame mount model. I don't have one, so I don't know for sure, but my father-in-law has one on his New Holland TC29D, and its a job to take his on and off.
   / Complicated but hear me out. #22
That's the problem, the ease of removing the backhoe to mount the brush hog. The 60 inch brush hog is not an easy removal and reinstall single-handed especially as one gets into the 60s!
At 71, I am very thankful for still being able to swap implements, including one of those big backhoes, but your point about seniors doing this stuff is so true. Candidly, I can't bring a lot of brute strength to these chores any more, and working smarter has to make up for it. For example, setting things up so my equipment is parked on concrete, out of the weather made a big difference for me. Among other things, my implements can be parked on dollies so even an old fa#t like me can move and install them easily.
As for the TLB vs. adding a backhoe to a tractor, I was earlier trying to say that it is possible to get some serious digging done with a somewhat more modest setup than the commercial TLB. Just to illustrate, using the "Build my Kubota" pages on the Kubota website, you can configure an L4701 + loader + 9 ft. backhoe that has a sticker price of $41,040. That compares with the L47 TLB that stickers at $51,470. No question the L47 is a lot more machine, but the other one will dig pretty darn well too!
I can only suggest you personally look over the new equipment you might consider, make a plan for how you would actually be using it, and think about ways to streamline some of the grunt work associated with using equipment like this.
   / Complicated but hear me out. #23
I found the Kubota BH to be very easy to install/ remove, I copied their design when I built my BH and I can remove or install it in about 5 min The 3pt takes a little longer because of the quick hitch and top n tilt but still quick.
1454 (A57192)
1454 (A57192)
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
22FT Roadway Dry Van Pup Trailer (A56438)
22FT Roadway Dry...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
