mrkdmars
- Joined
- May 25, 2012
- Messages
- 9
- Location
- Neva, Wisconsin
- Tractor
- 04 Simplicity, Legacy XL Fel, front48" snoblwr, 54" mmw, 48"tiller, htd hard cab, tooth bar, 3pt 2" box hitch, forks on order
Helloooooo I'm new to the forum, although I've been reading it for a couple years. I usually can find what I'm looking for. This one has me confused. I have a 04 Simplicity legacy XL diesel. K92 transaxle. I recently blew a hydro fitting. The main feed line on the trans. A 45ー fitting now discontinued, dealer sold me a kit to change it to a 90ー and rubber line. Decided to do a fluid and filter change I put an after market filter on I saw on one of the forums. With the exceptions of some tight spaces all went well. When I fired it up (no leaks) the mid implement lift would not move and steering very stiff. The main feed goes to steering and then on to implements. Okay air? I cycled mid cylinder eventually got it working but very slow. Cycled steering off the ground for an hour. (No change) Giving it a day to search and ponder did hydrostatic air purge procedure (helped slightly). Thinking maybe the filter used was incorrect I put the old one back on. (No change) I think it's either air I can't purge or loss of pressure from small line? Not having a pressure gauge or able to get one until Fri, any suggestions?
mrkdmars
Legacy XL diesel 4wd, rear pto & 3pt, fel, 47" 2 stage sb, 54" mmm, 48" bush hog tiller, heated hard cab, rops, 3pt 2" box hitch, toothbar, forks on order. Looking 4 rear blade & bb.
mrkdmars
