connecting snowplow to bucket curl circuit
   / connecting snowplow to bucket curl circuit #11
Possibly, different valve will function differently but usually they have a position that does not activate the regen feature.
Email sent also.
also if you have a rear remote a couple of long hoses will work.
I have heard of people having to install diverter valves on the main boom lift lower circuit because of issues with the regenerative function.
I will play with the lever in the morning to see if I can find a spot that keeps it out of regen mode. No rear remote have contemplated installing those but never quite got there.
   / connecting snowplow to bucket curl circuit #13
That is what I did to avoid the regen issue.
ok so played with the controls this morning and couldnt find a spot where the regen wasn't working. Guess I will need to plumb it in permanently to the PB port sooner rather than later.
   / connecting snowplow to bucket curl circuit #15
Yea, typical regen on the loader.
You either need a diverter off the lift/lower, long hoses off remotes, double acting cylinders on the plow, or a separate valve all together.
There is no way to make your single acting cylinders work with a regen valve.
Some kubota loaders had ONLY regen. Others had an option to push past. Which would be all the way to the right and it will "feel" like going from lower to float.....only pushing right. If you dont have that, you have regen only and have to figure something else out
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
