Construction of Laminated posts for Pole Barn
   / Construction of Laminated posts for Pole Barn #1
buckeye
Bronze Member
Southern Ohio
New Holland TC-40
As I get closer to building a pole building, I have been reviewing the posts presented in the forum relating to such. The information contained in this forum is simply amazing.
After looking at these threads, the use of laminated or built-up posts really interests me. Compared to a standard 6x6 post, they seem to have some advantages. I don't mind the time it would take to make these laminated posts, but I was wondering about some basic construction techniques for such:
1.) I know we want to stagger the board joints, but is there a good rule of thumb for the length of stagger between the boards joints? 1-2ft or somewhere in between?
2.) What is the best way to combine the boards to make a good composite structure? Should a construction adhesive be used between the boards combined with mechanical fastening like deck screws or carriage bolts? What is a minimum distance between the use of mechanical fasteners?
3.) Is there a good standard length of board to get (8', 10') etc? I know I can get a really long board and cut it to length, but is there a good or preferred length for the board used in the pole? I would assume a minimum of joints would be preferable, but you never know.
Thanks for any information you may have!
   / Construction of Laminated posts for Pole Barn #2
<font color="blue"> Compared to a standard 6x6 post, they seem to have some advantages. </font>
Hi,
What would those advantages be?
Like to give some suggestions...but I am having trouble seeing the advantage of using a laminated post over a pressure treated 6x6 for a pole building...
   / Construction of Laminated posts for Pole Barn #3
<font color="blue"> What would those advantages be?</font>
Not having any idea myself - but would the cost be less?
6x6x12 pt vs. 2.5 - 2x6x8 yp & 2- 2x6x8 pt
   / Construction of Laminated posts for Pole Barn #4
I'll take a crack at it, and maybe generate some replies in correction to my statements. /forums/images/graemlins/grin.gif
I also like the idea of using them, especially using pressure treated in short lengths in the ground and splicing standard framing lumber into that, saving money and weight in handling the PT stuff. However, if I had a choice, I'd want to use laminated posts without spliced joints at all. After thinking about it, I thought I might pour concrete posts in the ground and build on them with standard framing lumber.
I have made a couple sets of pump jack posts from 2x4's - 20' and 24' lengths in the last 10 years. Standing near the top of my little 2x4 posts while pumping up the staging before bracing below (can't jack by the braces), I've developed a good "feel" for the problems encountered with biaxial loading. /forums/images/graemlins/blush.gif I only used two pieces to fit inside the jacks; a third piece would've significantly stiffened the posts by having every joint backed up or overlapped by two solid layers.
I did a little quick search and the only spec I could find was a maufacturer's recommendation that 6x6 posts be three continuous pieces of 2x6 glued, clamped, and nailed on 12" centers on both sides. Every comment I read gave the impression that gluing was crucial. The problem with unglued laminations is that you are kind of depending on the strength of the fasteners in one direction and on the weak axis of the lumber in the other (not totally but basically correct).
Personally, for the small structures I would build (under 30'x40'), I think only nailing and then locking everything into the building structure as construction progresses would keep loads pretty vertical. I'd say 24" overlap would be minimum - 48" would be better, and keep the joints as far away from each other as possible. As far as lengths of lumber goes, I always try to go 2-2-2 when making up a beam length that can't be done with standard lumber full length. For example, if you wanted 24', I'd go 16 & 8, then 12 & 12, the 8 & 16. It get's harder the longer you go, and you need to go 2-3-2 after a while to avoid close joints. It's easy to sit down with a 12" ruler and divvy up the length and see graphically how far apart the joints come, and try not to have two joints fall on each other on opposite sides of the post.
This is all seat-of-the-pants comment - I'd welcome some more intelligent comment, and I am getting closer to putting together some beams myself.
   / Construction of Laminated posts for Pole Barn #5
Buckeye,
Good set of questions. There are sources that would tell you in engineering terms very explicit answers to most of those questions. Now I'll tell you how I would do it.
1. Joint Stagger; Use as long of pieces as you can. If you need 16' post, use 3 2x6x16's. If you need 20' posts, 2 - 10 ft. for the middle, 2 -16ft. for sides and 1 8' to make up the difference.
2. Fastening, Bolts are strong but unneeded in a laminated pole. I am a big fan of glue but it is questionable on pressure treated wood. Screws are great but again unneeded on a laminated pole. Keep in mind that with a pole there are no shear loads or side loads. All the weight is being carried straight down. A laminated beam requires more attention to fasteners because of shear loads. For a pole, 2-16p galvanized nails every foot will be fine. (from both sides of course)
3. Board Length, Just depends on what you want to end up with. The longer the better for the most part.
Jim, let me offer an alternative idea. I have never used this system but will on my next pole building. The idea came from here on the forum and I believe the discussion was about Morton pole barns. Build a laminated pole from pressure treated lumber to a length that will reach your frost line plus 3'. Make the centerboard of this pressure treated pole 2' shorter than the sides forming a mortise or pocket. When these much easier to handle posts are set in the ground the pocket will be 1' above grade. Depending on the desired wall height of the building you can now insert a yellow pine 2x6 into the pocket. Bolt this joint together with 6 carriage bolts and add the side pieces to complete the upper pole.
What I like about this system is that one man can do it with out having to muscle around 16' pressure treated 6x6's You don't have to use pressure treated above grade so there is less twisting and shrinking and 12' are about as big as you will have to move.
Wow, sorry, I got carried away. /forums/images/graemlins/blush.gif There are a number of good ways to do your poles. Just make sure you are pressure treated below grade and down below frost line with good soil at the base. Any of the fasteners you mentioned will work fine.
MarkV
   / Construction of Laminated posts for Pole Barn #6
<font color="blue"> What I like about this system is that one man can do it with out having to muscle around 16' pressure treated 6x6's You don't have to use pressure treated above grade so there is less twisting and shrinking and 12' are about as big as you will have to move. </font>
MarkV,
I guess you hit the nail on the head as far as a possible advantage of a laminated post...the only thing I could think of was maybe needing extra height...
A post can experience side loads though...high winds would be an example...personally I kind of like solid posts...or posts that are laminated and glued together with a glue that won't fail.
16 foot 6x6 pressure treated posts are not all that hard to handle alone. Even easier if the tractor helps a little! /forums/images/graemlins/smile.gif
   / Construction of Laminated posts for Pole Barn #7
In additition to the price advantage and weight/handling issues I would assume that laminate posts would have the advantage that laminate beams do, lack of twisting and warping.
   / Construction of Laminated posts for Pole Barn #8
Hmm. If you use the combination of PT posts below grade and non-PT above grade, as MarkV suggests, then the problem of glueing PT could be solved by using 2-part Marine expoxy glue - comes in 2-2qt cans, mixes 50/50, and looks like yellow butter. Because those below grade posts are relatively short, the epoxy is not too expensive. Then, use regular contruction adhesive on the upper, non-PT laminates because there are no chemical issues. I would also stagger the nails left and right as you go along the post.
I would think the reasons for laminated beams have all been mentioned in various posts - less twisting and warping, easier to get whatever length you need, easier to handle, and definitely less expensive - 2x6's in shorter lengths will always be less expensive than the premium length and width stuff, which always has to come from one tree. Also, the whole thing may be stronger, because, while not cross-grained like plywood, you are interrupting the grain structure that goes all the way through a 6x6 and could lead to cracking or splitting all the way through. I'll bet it would be a little harder to break one the way Spencer accidentally did.
   / Construction of Laminated posts for Pole Barn #9
Adv: It's a lot cheaper, easier to work with, and stronger. Have you checked the quality of 6x6 of late? You don't get a knot all the way through, or a crippled up twisted mess.... And a lot of farmers are needing 18' or more sidewalls, hard to get 24' beams & pay for all that pressure treating...
The way to do it is the short pressure treated stumps like the one fellow said, then go up with regular wood. However, I've never seen the exact joint he describes. You never want 2 joints at the same spot. All that is left is a single 2x6 holding things down. you want all three pressure treated parts different lengths - one above ground level, one 2' higher, and the third 4' higher.
--->Paul
   / Construction of Laminated posts for Pole Barn #10
But three 2x6s don't make a 6x6, the finished dimension would be 4.5x5.5. A bit short on one side. /forums/images/graemlins/shocked.gif
2007 International 4400 Truck, VIN # 1HSMKAZN97H451429 (A44391)
2007 International...
2012 WESTERN STAR  4900 CRANE TRUCK (A45333)
2012 WESTERN STAR...
Pallet of Irrigation Hoses (A44502)
Pallet of...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
Lincoln Electric SA-250 Welder (A44502)
Lincoln Electric...
2018 WESTERN GLOBAL 8189 GALLON FUEL TANK (A45333)
2018 WESTERN...
