Conversion Factor
   / Conversion Factor #1
RJS
NW PA
Kubota B7500DT
Anyone out there know the conversion factor from cubic feet
to cubic yards?
I'm trying to calculate how much gravel I need for a driveway project.
   / Conversion Factor #2
There are 27 cubic feet in a cubic yard. 3x3x3=27./w3tcompact/icons/smile.gif
   / Conversion Factor #3
Divide cubic feet by 27.
3 feet x 3 feet x 3 feet = 27 cubic feet = 1 cubic yard
   / Conversion Factor #4
There are 27 cubic feet in a cubic yard. so divide by 27.
Remember though that when you talk to the gravel yard they talk in "tons" mostly so make sure they know you want 4 YARDS of gravel and that they do the conversion to tons. You could do the conversion yourself but I've found it's easier to let them do it.
   / Conversion Factor
Thanks everyone!
I never was any good at math.
3 x 3 x 3 is pretty simple, I should have thought about that.
   / Conversion Factor #6
For all things converted....mostly metric <==> imperial I usually refer to one of many web sites out there. Such as <A target="_blank" HREF=http://www.sciencemadesimple.com/conversions.html>Conversions</A>
They tend to be fairly useful.
Kevin
   / Conversion Factor #7
As a side mention, Think of it like this as well. A mini wheeler dump truck holds approx. 18 cy of material. Materials like sand or crushed limerock are going to weigh somewhere around a ton per cy. Depending on water content and specific material.
Soundguy
<font color=blue>"Remember though that when you talk to the gravel yard they talk in "tons" mostly so make sure they know you want 4 YARDS of gravel and that they do the conversion to tons. You could do the conversion yourself but I've found it's easier to let them do it. "
   / Conversion Factor #8
To figure out how many cubic yards of gravel your driveway needs try this. Take the length and multiply by the width, then multiply times the thickness. ( Remember that 6" equals 0.5",4" equals 0.33 and so on. ) Then divide the sum of all three measurements by 27 and you will have the number of cubic yards needed to do the whole drive.
Yanmar YFL-1575 33HP Utility Loader Tractor (A49461)
Yanmar YFL-1575...
PALLET OF (2) THERMOKING TRI PAC UNITS (A50854)
PALLET OF (2)...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2000 Dnya RGN T/A Trailer (A49461)
2000 Dnya RGN T/A...
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
