converting ac to dc
   / converting ac to dc #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Been kicking around a test idea recently. I have some high capacity ( read 100-120a ) rectifiers with associated aluminum heatsinks.. would be easy to work up a full wave bridge... while my big welder is a hobart235acxl.. and out of the question.. I also have a lil CH 30/7a a welder I use on sheetmetal... 1/16 and 5/64.
seems doable unless I'm missing something.
anyone ever do something like this? ie.. external rectifier pack for an ac welder?
soudnguy
   / converting ac to dc #2
soudnguy
Yep, have seen it (or at least I seen a little on TV!) Starts at about minute 3 a shot of the rectifier bank
[ame=http://www.youtube.com/watch?v=9lV4tzg4zn0]Homemade Tig Welder - Tig Welding Old School with Scratch Start - YouTube[/ame]
James K0UA
   / converting ac to dc #3
Oh by the way.. he says at the end.. "if you want to get your feet wet"..
Well what ever the He** you do, DO NOT "get your feet wet" as that can be dangerous while welding:laughing::laughing:
James K0UA
   / converting ac to dc #4
A friend of mine who lives down the road (happens to be the mayor of the city), has a store bought version. Uses it with an ac miller thunderbolt, said it works great.
   / converting ac to dc #5
Did you try it and was there smoke?
RC
soudnguy
it's on my list to do.. just have to get time.
i'm sure there will be smoke.. from burning rods.
the rectifiers are in some cases, depending on which i use, up to double rated for my application..
   / converting ac to dc #7
Plenty of folks have done it. I've seen some pics on Shop Floor Talk and Weldingweb but don't have the links handy.
Go for it!
   / converting ac to dc #8
That's all that was in an old Century 300 amp stick welder that I used to own. A big split transformer with an arm that moved the two halves towards each other, and a large selenium rectifier. The selenium rectifiers come in a heat sinked stack, so it's essentially the same thing. Just make sure the voltage rating on your rectifiers is high enough, open voltage X 1.5 minimum.
Good luck!
i remember the old sel rectifiers.. noisy suckers...
   / converting ac to dc #10
Yes and the biggest rotten egg smell you have ever smelled if you let the smoke out of one of them.
James K0UA
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2018 Hino 155 16FT Cab and Chassis Truck (A51692)
2018 Hino 155 16FT...
