Converting woodland to lawn
   / Converting woodland to lawn #1
extrapairofhands
Hertfordshire, UK
Kubota BX2350
Hi - great website and I am hoping you guys can help a daft englishman out! I am about to purchase a couple of acres of woodland of which I plan to turn about 1/2 an acre into lawn. The floor of the woodland obviously has a lot of fallen rotten timber which I will clear by hand and the few trees I do intend to drop I will grind out the stumps. However there is extensive coverage of ivy throughout the floor. I have a mid mount finish mower and rotavator on my subcompact kubota. I am nervous of using the mower in case i do come across something unseen (eg a raised root) so was thinking a flail would be better. Alternatively do I go straight to my rotavator and just mash up the ivy. What I want to get to is a flat seedbed for me to then lawn seed. Just wondering what your thoughts would be on the kit to hire. I live in the UK and the soil is pretty light - not rock strewn like you guys seem to all have!
   / Converting woodland to lawn #2
My inclination would be to first go with a broad spectrum herbicide to kill off the existing vegetation and then till the ground. Get a soil sample to determine the right mix of fertilizer and lime application and go from there. I use a broadcast seeder and drag, but there are other methods you might want to try such as a spray mix of seed, nutrients and straw applied by a professional.
Often times "new ground" such as this will benefit from running a subsoiler to break up the hard pan, but a small tractor would be hard pressed to do this at much depth, so deep tilling may be the best you can do.
Good luck, I am sure others will have more ideas.
   / Converting woodland to lawn #4
Welcome to the forum. Our plants are most likely different than yours so local advice would be best. Here I would spray the Ivy to kill and then till in. Ivy roots easily and spreads quickly here so I think tilling it in might spread it.
MarkV
I was going to spray with a weedkiller to try and get rid of the nettles and other weeds but I know from bitter experience that ivy is pretty resilient stuff.
Getting the seed to take will I'm sure be pretty tough but I have a shady lawn seed mixture ordered and the other trees aren't too dense.
   / Converting woodland to lawn #6
If the trees are very large, you wont be able to do any plowing or tilling due to the roots.
It may be best to hire a bulldozer to take it ALL out before you start to landscape and plant
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
LANDPRIDE RCR1242 - 4' ROTARY MOWER (A51243)
LANDPRIDE RCR1242...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
2011 Hyundai Sonata (A50324)
2011 Hyundai...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
