Coolant drain valve problem - Model C
   / Coolant drain valve problem - Model C #1
rownow
Not familiar with this type of valve. It seems to turn 1/4 turn CCW and click into what I assume is the OPEN position. Is that right? Don't want to break it by turning it further.
So with the valve "open", nothing comes out of the horizontal 3/8" hole. I remembered to remove the fill cap.
The drain hole was full of salt/sand before I started. Cleaned that out with a small screw driver and blew it out with compressed air before opening the valve. No luck.
I made a half-hearted attempt to remove the radiator hose, but it seemed to be really tight (only 190 hours on a 2006 Model C). Aborted that attempt as I did not want to take it off and then be unable to get it back on.
I figure there might be some more salt packed in the valve so I shot a stream of cold water into the hole of the closed valve for 60 seconds. No luck.
Next I opened the valve and warmed up the machine until the radiator fan came on. I was hoping that pressurizing the radiator might force the clog out. No luck.
Any suggestions? I like to change the coolant in the next 30 days.
500BBL WHEELED FRAC TANK (A50854)
500BBL WHEELED...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
