Coolant leakage
/ Coolant leakage #1
Kubster
Kubota B6000
Could replacing the Dynamo assembly on my Kubota B6000 be the cure for constant coolant leaking from the overflow tube.
/ Coolant leakage #2
No. The dynamo only generates power to charge the battery. There is no water pump on the B6000. The coolant flows by convection. I would test or replace the radiator cap first if you are getting coolant out of the overflow and it is not overheating.
Brian
/ Coolant leakage #3
If there was a container connected to that hose, and it would "bubble" as it leak's,,
it could be the sign of a head gasket issue, air getting into the water jackets.
Do as Brian suggested, you could also have your rad pressurized and check for leaks.
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
HARDEE 4R SPRAYER (A63291)
HARDEE 4R SPRAYER...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
Location Info Please
John Deere 5525 (A60462)
John Deere 5525...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
