Correct adjustment for JD 54" MMM "the edge" - anyone have a manual?
   / Correct adjustment for JD 54" MMM "the edge" - anyone have a manual? #1
KestrelMerlin
PA
John Deere 2305
I have a JD 2305 with hydraulic lift for the deck. I was told at the dealership that the deck wheels should not contact the ground in normal mowing.
My question has to do with adjustments so that the deck wheels will contact the garage floor at the same time when lowered. Right now, they each touch at a different time when lowered, so it seems to me that the deck is not level.
Do you make adjustments to the front attachment mechanism which is a large u-bolt?
Also, it seems to me that the depth setting of each wheel should be the same. Right now, the front deck wheels are set up higher than the trailing deck wheels.
Thanks for any insight that you have.
   / Correct adjustment for JD 54" MMM "the edge" - anyone have a manual? #2
Re: Correct adjustment for JD 54" MMM "the edge" - anyone have a manual?
I don't have a 2305, but in general for a three bladed deck:
Make sure tire pressures are correct.
Set the cut height to the most used position and lower the deck to that setting.
Set deck level side to side by adjusting the side lift links as needed (ckeck level at the blade tips, with the blades turned straight to the side -JD dealers sell a plastic gage that makes these measurements much easier).
Turn blades 90 degrees. so they face straight front to back, then measure deck tilt front to back (at blade tips). Front tip of the center blade should be 1/4" to 3/8" lower than the rear tips of the side blades - adjust as needed using the front hanger (big U bolt),
The gage wheels should then be set so that they clear the concrete by about a 1/4".
Thanks John! That's what I needed to know.
I appreciate the help!
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
