Aussiebushman
- Joined
- Jul 31, 2008
- Messages
- 252
- Tractor
- Ford 6000
On this forum we tend to pride ourselves on our self-reliance. Not for us the easy way out of taking machinery to the stealer for simple maintenance or repair. No, we can do this ourselves, generally using various bits and pieces left lying around the shed, with old fencing wire, epoxy, duct tape and cable ties being high on the list of acceptable materials.
Therefore, when the compressor fails to deliver more that 5 PSI, there has to be simple fix, right? First, we reseal the leaking delivery lines - no significant improvement. Then we discover there is little or no oil in the unit -simple enough to refill. Ah we find a leak around the 1 cent Chinese plastic filler-plug. What looks like a plastic thread isn't one; it is merely a stopper with an O-ring that pushes into an unthreaded hole and naturally, we do not have an O-ring of the correct size. How about some thread tape? No, it still leaks.
Now for some inventiveness, starting with a search through our old bits of rubber (mostly now perished) until we find a bit of oil-rated hose that with a solid rubber plug jammed inside makes a pretty good fit into the filler hole. Start the compressor and hey it works! That is, until the pressure reaches about 40 PSI and the plug blows out, along with most of the (now black) oil.
How lucky that one was standing slightly to one side watching for leaks. In this way, only about half of the oil ended on ones face, hair and clothes. The rest hit the roof lining and is still dripping conveniently, should one wish to take a shower too.
Happily, a bit of fencing wire and a hose clamp was the answer. A couple of twists of wire around the base of the compressor holds everything in place really well. The moral of the story is that one should have used fencing wire and duct tape in the first place, but the upside is the excellent conditioning effect on the hair and skin. Who needs to buy cosmetics when we can make them ourselves? A woman with her mouth open to talk at the time of the incident would also have acquired free mouthwash as well.
Regards from OZ
Alan
Regards from OZ
Alan
