Cost of Aftermarket Cab for 3520?
   / Cost of Aftermarket Cab for 3520? #1
morrisond
Hi my dealer has an Demo 3520 without an Cab, can you retrofit the Deere cab or how about aftermarket? Any idea of cost?
   / Cost of Aftermarket Cab for 3520? #2
You cannot "retrofit" a JD cab. The tractor is basically built around it-that's why they are so nice!
An aftermarket cab will be anywhere between $2k and $4k depending on options, BUT it will be louder, the heat won't work as good, there will be no AC, and it will not look factory.
If you want a cabbed machine-then pony up the money for a factory model and you won't be disappointed.
Some aftermarket names to search for though are:
Curtis Cabs
Jodale Perry Cabs
Laurin Cabs
Sims
   / Cost of Aftermarket Cab for 3520? #3
kennyd is right... I priced both $3500 more for that sweet Deere Cab. Order it and it is worth the wait......
   / Cost of Aftermarket Cab for 3520? #4
Did you check TractorHouse for used CAB 3320s, 3520s, 3720s near your local area?
   / Cost of Aftermarket Cab for 3520? #5
Someone had a posting for an aftermarket cab for about I think it was $800 Im gonna look and see if I can find it. V
   / Cost of Aftermarket Cab for 3520? #6
Go to JD owner/operator form On the third page was a post " I bought a cheap enclosure... " I believe it said in there that they had them for other model JD. V
2020 Kubota Sidekick RTV-XG850 (A47384)
2020 Kubota...
2020 JOHN DEERE 524L LOADER (A51242)
2020 JOHN DEERE...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
