cost of repairing a hydro drive transmission
   / cost of repairing a hydro drive transmission #1
72chevy4x4
Bronze Member
John Deere 3038e
On a Kubota 2710hst, which has a 27hp 4cylinder diesel and a three speed hydrostatic drive, does anyone know/quess as to the cost of repair? The low and medium speeds work as expected, but the high speed feels like it's not catching (lack of power). Guess it could be driven aroudn in L and M, but H is needed at times too :) Is there any chance of damaging these drives by running too fast and carrying/pulling/mowing too much of a load for long periods of time (or any other reason you can think of they would fail)?
   / cost of repairing a hydro drive transmission #2
High has enough power to travel on a smooth road with no uphill to it. Some tractors are better then others. My KubotaL48 was terrible in high range other then road travel. On the otherhand, my L3830 does very well. My dealer told me that if they ever get a bad HST transmission in, the manufactuer (Kubota) recommends they simply order a factory rebuilt and install it rather then repair the old one.
   / cost of repairing a hydro drive transmission #3
Chevy
The L-M-H is not done in the HST. It is done in (I think) the mid-case. If it's not grinding or slipping out of gear and into N, then I don't think those steel gears are the problem. If the L and M work as expected, the HST is probably ok too. Maybe an oil flow issue, a faulty pressure relief or even dragging brakes. (Pure guess).
You may have a clogged filter or inlet screen. Do the simple things first, then go deeper.
jb
   / cost of repairing a hydro drive transmission #4
HST H gear is for moving on the road with no load.
Bob
   / cost of repairing a hydro drive transmission #5
Can you tell if it is engaging in high? I read post where this problem was a linkage adjustment. In that case the HST was fine, just that the lever never made it all the way and H was never engaged.
   / cost of repairing a hydro drive transmission #6
What? An HST tranny with a problem? Surely you jest... (grin)
Soundguy
   / cost of repairing a hydro drive transmission #7
Soundguy
You can only hope! Maybe it's just a worn clutch...... NOT!
Land Honor Portable Screener (A50514)
Land Honor...
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 24"...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
1988 Butler Equipment Trailer (A50515)
1988 Butler...
Wolverine Quick Attach Hydraulic Slide Pallet Forks (A50515)
Wolverine Quick...
