CountryLine Post Hole Digger PTO Shaft
   / CountryLine Post Hole Digger PTO Shaft #1
MelWil
JD 3240
Our PTO shaft broke today. We are looking to replace it, but having a heck of a time. Is all CountryLine Post Hole 3 point auger PTO shafts the same? We found a different PTO shaft at a local tractor supply but the pin hole is slightly too small and we cannot find the model number on our CountryLine Post Hole Digger.
Does anyone know if all the PTO shafts for CountryLine the same size? If so, anyone know the size or model number so we can replace it?
Thanks for the help
   / CountryLine Post Hole Digger PTO Shaft #2
On a shear bolt style driveline the pin hole is normally small. Its a pilot hole and you drill it out to fit your needs.
   / CountryLine Post Hole Digger PTO Shaft #3
I had to replace a U-joint and yoke on my County Line PHD. Tractor Supply, where I bought it, was almost no help. But they did give me the number for the County Line manufacturer and they gave me the info I needed to buy the parts from someone else. I don't have the number handy but if you give Tractor Supply a call I'm sure they can give you the same info they gave me.
Eric
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
