Coupler hard to attach follow up
   / Coupler hard to attach follow up #1
Tarnold
Ellijay ga
Ls 3038h, ford 1900
Last week posted about difficulty in reattaching my grapple due to excessive pressure in the connectors. Many responded, thanks, but have now come up with a sure fire way to relieve pressure without a hammer or other excessive measures. At the Lowes store they are doing away with Bessy(the very BEST clamps) and found a 4" split C clamp. This is where the clamp frame opposite the screw is split, like a claw hammer. Take your ag coupler and fit in this claw and screw down till plunger is depressed. BUT MAKE SURE you wrap with a shop towel first(I didn't) but you learn. This is for the male side, on the female side I cut a 1.5" 1/4 dowel to use as a plunger as clamp screw would'nt fit down enough. Did'nt really use the dowel though as enough pressure was relieved from the male side to allow an easy coupling. Clamp cost about $6.
OP again. As a follow up, it might be best to do the female side first as most of the releasing spray will be contained within the coupler. Thankfully I wear glasses as my face took most of the releasing spray.
   / Coupler hard to attach follow up #3
Can you post picture of clamp?
Wedge
Yes, that's the one. 4"....remove the two plastic "feet" that just slip off, metal to metal gives a better grip.
   / Coupler hard to attach follow up #6
Thanks for posting the followup and your solution.
I still think one tractor per attachment would be nice:)
Electric Concrete Mixer (A51573)
Electric Concrete...
378538 (A51573)
378538 (A51573)
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
