Covered Truck Bed
   / Covered Truck Bed #1
lakngulf
Veteran Member
Lake Martin Alabama
Kioti CK30
On all my previous trucks I had a tool box attached up front just behind the window. Worked great for whatever I needed. Well, my current truck has a covered bed, the type that will roll up out of the way when open bed is needed.
My issue is "What to do with tools, nails, bungee cords, wasp spray, extra boots, knives, level, rope, first aid kit, come-a-long, fence tools, duct tape, etc = All kinds of stuff I stored in the tool box. What are some good tips and techniques for storing and accessing this stuff without removing the cover?
   / Covered Truck Bed #2
you have tool boxes, that fit over and onto the edges of the truck sides. guessing what you are use to. and then you have more of a 5th wheel setup. that set down and level with truck bed sides. so say a camper doesn't nail the tool box, or bed cover or like can fit directly over everything.
go with a hitch rack / tool box. that fits into receiver were you might pull a trailer or like.
i would imagine someone makes some sort of "drawer" setup. "much like kitchen drawers" that slide back and forth. on some rails for access to stuff.
   / Covered Truck Bed #3
I've seen trucks used by plumbers with roll-out shelves. Drop the tailgate pull out. Maybe not practical because for heavy bulky loads, it will just be in the way, get damaged, etc.
   / Covered Truck Bed #4
OR if you don't need all the bed space, just put the tool box at the very front as you had it on your other truck, then mount your roll up bed cover right up against it. I little silicone seal around each of them would make them water tight. If you have the roll up bed cover like I have seen, they can be rolled out and locked in variable positions so that would be my solution
   / Covered Truck Bed #5
You can get tool boxes that sit below the bed rail. There are many different styles. One that go across the bed at cab, fender well boxes, drawer stacks. Check out weather guard they have everything but the drawer stacks I think. They even have a Pack Rat. It's a big drawer that fits in bottom of bed and pulls out full length. It's made to go under cross boxes and side boxes and let you put drawer stacks beside also. Some utility companies around here are using this setup instead of service beds. Northern tool and Sears have the drawer stacks.
   / Covered Truck Bed
A guy on another forum has one of these on each side of his truck bed. Looks like quite a good option, but a maybe a little expensive.
Amazon.com: Undercover SC201D Black Swing Case Storage Box: Automotive
   / Covered Truck Bed #7
Kinda low tech, but I use milk crates, tool boxes/bags, rubbermaids, etc. Allows me to quickly grab whatever out of my shed and put it in the bed where the tonneau cover keeps it dry and out of sight. I don't have a roll up one though, I have one of the tri-fold ones that can't be opened when the tailgate is locked. If your rollup one is not secure, you may still want a secure box to keep your tools safe.
   / Covered Truck Bed #8
That's what I was calling a fender well box. They look nice but don't hold enough for me so I can't coment on them other then they are made. You can get them in metal or plastic. I didn't think it was a bad price. As a new crossbox will run 500-700 for a weather guard. Looking at them myself. My current one is in it's 4th truck and some welds are starting to crack. If I have a box I like I never let it go with the truck.
   / Covered Truck Bed #9
I use rubbermaid milk crates and storage bins. Because they will always slide forward, I throw in a hoe to pull them back to the tailgate area when I need them.
   / Covered Truck Bed
Good idea. Do you have a mat in the bed of the truck? Or do they slide on metal?
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
