Crankcase vent
   / Crankcase vent #1
Daveinutah
AG KING 3540
I have a 2005 ag king 3540 that spurs oil out of breather
   / Crankcase vent #2
Welcome to TBN
Is engine oil level at "full mark"? If so it sounds as if piston compression is entering crankcase via bad piston rings
   / Crankcase vent #3
Excessive 'blowby' is always an indicator of worn internal parts in an engine or, clogged return oil passages in the head caused by accumulated sludge blocking the return oil from draining back into the crankcase as 99% of breather tubes originate at the valve cover. Of course like Jim said, if the motor is overfilled with oil, it can also 'puke' out the draft tube. First thing to check would be the oil level and then pull the valve cover and inspect the drain back passages for sludge blockage, both are inexpensive to remedy and certainly much cheaper than an engine teardown.
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
