Cruise control upgrade
   / Cruise control upgrade #1
dirtworksequip
Veteran Member
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
I just installed the JD cruise control upgrade on my 3520 and can not get it to work. I followed the directions to the letter. What am I doing wrong?
   / Cruise control upgrade #2
Press up on the left most switch, depress the pedal to the desired speed, press down on the second switch. Try that.
   / Cruise control upgrade #3
Also watch the diagnostic indicator when attempting to set the cruise; it may be flashing a code. On my 4310 if the brake pedals are not locked together the right brake sags and doesn't allow the cruise to engage. Trying to set the cruise only results in a flashing light on the fender.
Thanks for the suggestions. I disconnected & reconnected the battery and was then able to enter the correct codes and get it programed.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
CAT 930M (A58214)
CAT 930M (A58214)
DEUTZ MARATHON...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
