CT 440 engine dies after 15 minutes
   / CT 440 engine dies after 15 minutes #1
megofig
bobcat ct440
My CT 440 runs fine for 10 to 15 minutes then loses power and dies. I wait for an hour or two and it will start again but then does the same thing. Any ideas?
   / CT 440 engine dies after 15 minutes #2
I would start with the fuel system. Change the filters, confirm fuel flow from the tank out. Another fuel component that could cause problems are the actual fuel lines. Check connections and for cracks that can suck air.
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
71057 (A49346)
71057 (A49346)
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
