Backhoe Ct440 with backhoe
   / Ct440 with backhoe #1
ditchdigger78
Montana
Ct 440
Does anyone have a bobcat backhoe on a bobcat ct440 that has a cab. I have herd mixed info,some say the cab is in the way of the seat on the backhoe. Thanks.
   / Ct440 with backhoe #2
I haven't seen one on a cab tractor but imagine the seat is close, you would be resting your back against the window. Couple weeks ago I read in the Kioti forum that there are 1 or 2 brands of backhoe Kioti specifies Do Not install on cab tractor. I think that is becasue the seat will hit the window.
   / Ct440 with backhoe #3
Update on this question. I was reading through some material at dealer, Bobcat recommends removing the back window when the backhoe is installed.
   / Ct440 with backhoe #4
If you did not purchase the backhoe yet i would go with a woods ground breakerX over the bobcat backhoe. I could of went with the woods but went with the bobcat on my ct450. I have 120 hours on my machine and had to have all my seals replaced on backhoe already. The dealer told me they have a poor seal setup on the cylinder. I also heard the cab and backhoe dont fit. Thats why you never see them setup like that at dealers.
   / Ct440 with backhoe #5
I have the Bob Cat hoe....never heard of the seals being bad.
   / Ct440 with backhoe #6
I have a bobcat 9 hoe since 2009 and have many hours of use on it and have to say no leaks what so ever. And yes they do work fine on 4 series cab tractors, no problems with seat clearences. I once was told there was a different mounting bracket used with cab tractors...
American Sanders Floor Sander (A45336)
American Sanders...
2005 Ford F-250 Pickup Truck (A44572)
2005 Ford F-250...
1999 Whitecap 191 Center Console 17ft Fishing Boat 20ft T/A Trailer (A44572)
1999 Whitecap 191...
2021 Ford F-150 Crew Cab Pickup Truck (A44572)
2021 Ford F-150...
2015 John Deere 4052R Utility Tractor (A44571)
2015 John Deere...
2025 AllMetal K1912 UNUSED Livestock Metal Shed (A47484)
2025 AllMetal...
