cub cadet 1000 trans problem
   / cub cadet 1000 trans problem #1
jaab
western new york
cub cadet 7530
i recently inherited a very nice cc1600 tractor with a 16.5 vanguard motor. the thing is in nice shape except that it doesn't go in reverse. the differential seems to work with the rear off the ground, so i imagine it shouldn't be too big of a problem. my local dealer that i usually don't deal with says it needs a new rear end to the tune of $750 or so. i took the machine back and tore into it myself and found a broken gear. the dealer said these parts are not available. the daeler i bought my 7530 cc from is much more honest but about 50 miles away, i didn't think this little machine warranted the expense of taking it there. any ideas where i can get parts?? this seems to be similar to MTD rears, is this true? by the way my 7530 is an absolute joy to own and seems to be indestructible.
   / cub cadet 1000 trans problem #2
I take it the 1600 is some type of gear drive? If a hydro goes forward, it will go in reverse as well provided the pedal linkage is adjusted.
Joel
   / cub cadet 1000 trans problem #3
I would give your "honest" dealer a call and find out what they say. I would think they can advise you on what to do. One way or another it would need to be repaired.
   / cub cadet 1000 trans problem #4
A few things here from looking at C&G's site. The transmission for the 1600 is only sold from Cub Cadet as an assembly, in that event the dealer was correct. But, the list price for it is $369.54. This is a single speed transmission with a variable speed belt drive. But, if you can determine the manufacturer of the transmission, parts may be available directly from them. It will likely be made by Peerless/Tecumseh or Hydro-Gear. If all that fails, a machine shop might be able to fabricate the broken gear.
Hydro-Gear – Welcome
Small engine and power train products from Tecumseh (UK)
2016 Nissan NV200 Cargo Van (A46683)
2016 Nissan NV200...
3092 (A46502)
3092 (A46502)
Wesco Pallet Fork Drum Grabber (A46502)
Wesco Pallet Fork...
12in Backhoe Bucket (A48561)
12in Backhoe...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A46683)
2006 GMC C8500...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
