Cub cadet 122 Loader
   / Cub cadet 122 Loader #1
yellowcub
MA
Cub Cadet / 122
Hello to All, here are a couple shots of my customized Cub Cadet 122. I have done alot to this bad boy. The previous owner did the customization to the tractor. I dismantled most of the tractor. I sand blasted the frame, fenders, hood, axles, 2 coats original color, replaced most of the wiring harness, rebuilt the carb, new points, plug and plug wire, new coil and voltage regululator, new front wheel bearing's, new front tires, new muffler, different seat with new custom seat cover. New emblems all around. It also has tandem rear wheels as you can see. The front loader is powered by 3 electrical cylinders capable of lifting 1500lbs each, there is 2 for lifting and 1 for adjusting the pitch of the bucket... Enjoy
http://i97.photobucket.com/albums/l219/donwjr/CUBCADET1.jpg
http://i97.photobucket.com/albums/l219/donwjr/CUBCADET2.jpg
   / Cub cadet 122 Loader #3
Great idea !!! Can you give the part number for the actuators.... What is the cycle time... I'd like to rig something like that for a dump cart using actuators on each side of the bed. Any problems keepin the actuators in sync....
   / Cub cadet 122 Loader #5
Nice job. My first tractor was a 122 cub. Like they say, they were built like the big ones !!
   / Cub cadet 122 Loader #6
That's a very cool idea. How does the elecrical system handle all of those actuators? Did you have to upgrade that? Also, how are the upright arms supported. Seems like you might need to brace them to the front of the frame. It would help stiffen the unit and prevent some twisting from a load that was not centered in the bucket. With 3000 lbs of lifting power from those actuators you are going to need a lot of weight on the rear of the tractor. Be careful.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
UNUSED 10PCS 3.9 in. Polyester Lifting Strap (A50860)
UNUSED 10PCS 3.9...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2021 Chevrolet...
1998 Pierce Enclosed Cab Fire Truck (A50860)
1998 Pierce...
2022 Club Car...
2022 Massey Ferguson 1825E 4WD Tractor (A50860)
2022 Massey...
