Cub Cadet 128/Kohler K-301 Crankshaft Accessory Removal
   / Cub Cadet 128/Kohler K-301 Crankshaft Accessory Removal #1
jet62095
New England
1968 Cub Cadet 125 Hydrostatic, 1974 Cub Cadet 128, 1961 Hinomoto E-21
I'm trying to remove the front PTO, (Screws stripped) the starter generator pulley, and the flywheel. I bought a flywheel puller, but it will not work as my flywheel doesn't have any puller holes. Do you have any ideas on how to remove these parts?
Thanks for your help,
John
   / Cub Cadet 128/Kohler K-301 Crankshaft Accessory Removal #2
1. front pto has 2 setscrews per hole. Sneaky little buggers.:mad:
2. Crankshaft /flywheel removal. Ummmmm, we always drove two cold chisels as wedges between flywheel and block, BUT NOT TOO HARD.
loosen flywheel nut about 1 turn, then place a second nut on the shaft and snug it gently up to the first. Then with a small sledge hammer hit the second nut squarely. This should loosen the flywheel. Don't hit the crankshaft threads, hit the nut squarely. If you don't use two or more nuts, you will almost certainly snap the threaded portion of the crankshaft. This is NOT a good thing. Think first, smack second.:D
My Front PTO set screws are stripped, Any advice on getting them out? And I will give that a try on the flywheel!
1979 Lincoln Versailles Sedan (A45336)
1979 Lincoln...
2007 MACK CHN613 (A45333)
2007 MACK CHN613...
2016 Honda Accord Sedan (A46684)
2016 Honda Accord...
AGT 3pt or SS Seeder (A47809)
AGT 3pt or SS...
2017 Ditch Witch FX30 Vacuum Excavator System T/A Trailer (A45336)
2017 Ditch Witch...
2007 John Deere 9570 STS Combine  Premium Cab  FarmTRAX Yield & Moisture  1,846 Sep Hours (A46878)
2007 John Deere...
