Cub Cadet 1525 Electric Clutch
   / Cub Cadet 1525 Electric Clutch #1
FlyBoy5
How do I keep the engine shaft from turning while torqueing the mounting bolt? I used a large channel-loc to loosen it.
Thanks for your answers.
JW
   / Cub Cadet 1525 Electric Clutch #2
You can put a wooden dowel in a spark plug hole then slowly bring the piston up to rest against the wooden dowel. Some people stuff a rope in the spark plug hole then bring the piston up.
Thanks, what a crude way to do something. Looks like they could have added a couple of flats to the spacer even if they to make it a little thicker.
   / Cub Cadet 1525 Electric Clutch #4
Yep that isn't a preferred way but it would get the job done. Just watch for getting rope jammed in a valve or the wooden dowel broken off in there. Other wise a strap wrench around the flywheel. I am surprised there hasn't been more of the wiser guys giving advice on your question. Good luck. Maybe let us know what you did and how it went.
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
