Cub Cadet 2042
   / Cub Cadet 2042 #1
tgf600
I just purchased a 2042 mower. Even though it has more horsepower than my old mower, it seems to be running very low rpms.
Can anyone tell me how to turn up the rpms on this new mower.
I know its not recommended but my old one was turned up and did well.
Any info appreciated.
   / Cub Cadet 2042 #2
Check for range of motion of the throttle cable. You can loosen the cable hold-down & reposition the throttle cable as needed. If you are under warranty, call your dealer & see what they can do about it.
G/luck
Joel
   / Cub Cadet 2042 #3
Sorry but due to EPA regulations you cannot adjust the throttle on any of the engines manufactured.
The engines are designed to operate at full throttle only.
YOu need to have the dealer check the engine over. Possibly you need your governer adjusted.
Cub
   / Cub Cadet 2042 #4
</font><font color="blue" class="small">( Sorry but due to EPA regulations you cannot adjust the throttle on any of the engines manufactured.
The engines are designed to operate at full throttle only.)</font>
Throttles are infinitely adjustable on any LT/GT. Adjusting RPM's is another issue. You'd have to do some of your own handywork to *adjust* the governor for more RPM's. You'd shorten engine and trans life by doing that however.
G/luck
Joel
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A46878)
2021 New Holland...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A46878)
1999 John Deere...
Box of Clevis (A47809)
Massey Ferguson TO35 Tractor (A47809)
Massey Ferguson...
JMR 66in Grapple (A47809)
JMR 66in Grapple...
Ford F250 Flatbed (A45336)
Ford F250 Flatbed...
